585,906 active members*
3,804 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Trying to flatten a simple sheet metal pipe with chamfers but SW won't let me!
    Jul 2015
    21
    I have a simple sheet metal pipe that has a few chamfers on it and I'm trying to flatten it but keep getting the error "This part contains features that cannot be unbent."
    I've spent 2 hours on this so far and for the life of me, can't get it to work. I've attached the Solidworks 2014 file to this email and would really appreciate if someone could take a look and help me out.
    Thanks in advance.
    Attached Files Attached Files
    Mar 2008
    683
    Re: Trying to flatten a simple sheet metal pipe with chamfers but SW won't let me!
    Suppress your chamfer then flat pattern. I'm using 2017 and it worked for me. Then add your chamfers on the flat pattern configuration and make another configuration for the finished rolled pipe.
    Jul 2015
    21
    Quote Originally Posted by warrenb View Post
    Suppress your then flat pattern. I'm using 2017 and it worked for me. Then add your chamfers on the flat pattern configuration and make another configuration for the finished rolled pipe.
    You opened the file and flattened it as it is and it worked?
    Sep 2006
    245
    I use a different CAD program, but I often just re-draw the component. Use the edges of the existing part to position the new part. Should take less than 2 hours.
    Steve
    Mar 2008
    683
    No. Remove the chamfers in your flat pattern configuration. Then it flattens fine
  1. Acme Fiber Laser Cutting Machines for Metal Tube/Pipe
    By ACMEFIBER in forum Fiber Laser Cutting Topics
    Last Post: 08-17-2017, 06:45 AM
  2. Replies: 13
    Last Post: 12-30-2014, 06:34 AM
  3. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
  4. Replies: 6
    Last Post: 10-05-2013, 03:40 AM
