Hello
First, i dont know if i am right here. I am using fusion 360 so it cant be that wrong.
I want to mill pmma with a 3mm one flute bit. If I go 1mm deep and 150mm/s (6 in/s) i get a good result, but it is extremly slow and takes 10 hours per piece. If i go 500mm /s (20in/s ) its a complete fail, because the mill dodges up or to the side. I wanted to give my router one last chance bevore i buy a better one. What if I go 150mm/s but 3mm deep? I would spray water to the mill to prevent melting
Do you think that could work? Maybe you tried it yourself or you may know that deeper needs even more power than faster or etc.
Thank you
