585,927 active members*
3,954 visitors online*
    Oct 2017
    Cutting after engraving acts different then cutting alone
    I'm new to this forum, not new to laser cutting and engraving. I have been doing this since 2011.
    I started with an affordablye Ch laser, now I have a BRM, bigger, stronger, higher quality.
    As I mostly cut and engrave parts for modelbuilding, I experienced the following with my new lasermachine.
    Example :
    Job with 2 layers
    Layer 1 engrave bitmap sp 500 power 30
    Layer 2 cutting sp 20 power 18
    When I only execute Layer 2 : perfect result, material cuts nicely.
    When I execute Layer 1 - Layer 2 (cutting after engraving) : material not cut completely. The early cut lines are bad, the later ones become better but not acceptable.
    I can work around this by adding an extra layer in between, letting the laser draw some lines, outside the original work I need. But this is not the way it is suppose to work.
    My first machine did not behave like this. It seems the laser has to rest a little bit before using lower powersettings after engraving.
    I can also higher the power but this means more burning and also cut lines being not as fine as wanted .
    Anyone experienced this?
    info : Software RDCam V6.33.44
    Paul
    Aug 2016
    119
    Re: Cutting after engraving acts different then cutting alone
    Do you need to cut those extra lines outside the work area, or does a simple dwell work the same? If your problem is due to heat and increased electrical resistance somewhere, you might be able to get back to cutting sooner if the laser power is off entirely between etch and cut? I have no experience with these machines personally, just industrial (multi Kw) lasers
    Jan 2007
    229
    Our Chinese laser is very poor at cutting with a power setting in the software of close to 28-30%.
    Less than 27% and you're lucky to get a mark at all.
    IN your case I'd suggest trying a higher power setting, and going faster. eg 1.5 times the speed, and 1.5 times the power - and see how that appears.
  1. ATC CNC router for 3D engraving and cutting
    By stylecnc in forum News Announcements
    Last Post: 05-05-2016, 04:56 AM
  2. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  3. Engraving and Cutting Leather
    By Kcinnick in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-22-2013, 09:54 AM
  4. Cutting and engraving
    By munich2007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-25-2007, 03:36 PM
