Has anyone experienced the 2.2kw Chinese spindle/vfd shutting down due to over amperage? All I am doing is cutting holes in my MDF spoilboard. The VFD shows the error for over amperage during normal operation. E.OA.n I believe it is. I have used settings from mactec and others on here to set it up. The max current was set at 9. I bumped it to 10 and it still went down after some cutting. The spindle is hot but not so hot you can't put your hand on it.
I feel like something is wrong with the spindle. Resistances between the pins is around 25 ohms between each of them. 1-2, 2-3, 1-3 Seems way high from what I have seen others post on these forums.
What do you guys think?
