586,009 active members*
4,740 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > 2:1 ratio bevel tool: irrational angle - don't seem to exist
    Oct 2017
    we just want to machine a cut that is a 2:1 slope - ie 2 high, 1 deep.
    The only way we've found to get a tool like this is by getting it custom made for several hundred GBP.
    Any other suppliers out there for this 'simple' requirement?
    Ta,
    Mark.
    Dec 2013
    5717
    Re: 2:1 ratio bevel tool: irrational angle - don't seem to exist
    If I understand your description correctly you are looking for a tool with a 54° included angle (27° per side) I don't think I have ever seen one of those.
    Is it not possible to angle the part to get the required cut angle?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2010
    4256
    Search on Tapered End Mill. Hordes of companies selling. Finding your required angle may be more difficult.
    Consider a slight redesign to fit with what is commercially available? 25 degrees is available.
    Cheers
    Roger
    May 2017
    56
    You are correct on this, everyone either offers a 25° or a 30° Angle per Side Tool when you need a 27° Angle per Side Tool. If you have tolerance for the 25° or 30° then there are plenty of options. If not then the best bet is to take the 30° tool and modify it to the 27° angle per side you need. You can contact a local grind shop to do this or we do this in house and can get you a price if you like. Just need to know Shank Diameter you prefer, Length of Cut and HSS or Solid Carbide to get you a price (we run into special angles all the time and modify them often). Hopefully this helps
    Mike
    www.toolhit.com
  1. Mag Pot Tool No Exist is not on!!!??!
    By Ecmdrw5 in forum Okuma
    Last Post: 10-05-2011, 11:23 PM
  2. Does this lathe turning tool bit exist?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 03-12-2008, 02:37 PM
  3. 45 degree bevel on angle iron
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 07:00 AM
  4. What tool is best? Bevel/Chamfer
    By dneisler in forum MetalWork Discussion
    Last Post: 11-29-2005, 04:44 PM
