585,759 active members*
4,058 visitors online*
    Oct 2017
    11
    Good Polycarb finishes
    Anyone have any good recommendations for milling polycarb for a good finish. I'll be milling out a .250 deep window in a .375 thick piece of clear polycarb. I'll volume mill out the window leaving a few thou on z to run a clean up pass with a .250 downward spiral 2 flute endmill at maybe 6000 with like a .200 cut width. So there will be some tool paths left in the part. I know heat helps so maybe hit it with a torch for a second i don't know. Maybe spin it as fast as I can? 8000, largest endmill possible?
    Jun 2010
    4256
    Re: Good Polycarb finishes
    If you go really fast ... you will melt the plastic and have a LARGE mess.
    Really sharp new cutters at a moderate speed, followed by polishing.
    Cheers
    Roger
  1. Replies: 9
    Last Post: 07-26-2017, 11:11 AM
  2. How to remove finishes off aluminum can?
    By mcrado in forum MetalWork Discussion
    Last Post: 04-14-2017, 09:46 AM
  3. Noisy, clunky and bad finishes
    By quapman in forum Tormach Personal CNC Mill
    Last Post: 01-16-2014, 05:39 PM
  4. RFQ Injection mold polycarb
    By dandy7200 in forum Employment Opportunity
    Last Post: 03-24-2010, 03:35 PM
