Regards
Amit Kumar
Hi Amit,
Please tell us what you understood and what you tried to do. Post your Screen Script and the C Code that writes the temperature to the Screen.
Regards
TK
http://dynomotion.com
Regards
Amit Kumar
Hi Amit,
Please show us your Screen Script and the C Code that writes the temperature to the Screen.
Regards
TK
Regards
Amit Kumar
Hi Amit,
You asked this question last year. See:How to make jog buttons for U axis similar to X, Y, Z, A, B, C axis.
https://www.cnczone.com/forums/dynom...ml#post2094854
Please respond to our suggestions there.
Regards
TK
Hi tom,
I have a doubt, How to calculate maximum ADC counts to input in your suggestion above mentioned. When i am using 12V power supply, and SEMITEC 104 GT2 Thermistor. ?
What will be the max ADC counts that i can put in MDI to measure minimum and maximum temperature range.
Waiting for your kind reply
Regards
Amit Kumar
Hi Amit,
I don't really understand what you are asking. The ADC min-max range id 0-4097. Increase/decrease ADC setpoint gradually to test the range of temperatures you need.
I Google searched for your sensor and found this:
Attachment 394448
I believe this is the appropriate resistance formula
Attachment 394450
From KNozz Manual:
ADC = 4095 x 10K / (10K + R)
Plotting
Attachment 394498
What temperature range are you expecting? What temperatures for ADC settings do you observe?
If my math and plot is correct resolution will be poor over 150C.
I've attached the Excel spreadsheet.
Regards
TK
Hi Tom,
Thanks for your reply.
I am expecting temperature range from 0-400 degree C.
And i am getting temperature from 25 degree C to 287 degree C.
After that it is not going forward , how to configure Knozz to reach that such temperature range. And how to increase resolution for thermistor calibration. And What voltage and current powersupply should I use to reach such temperature (0-400C). What ADC count is required to reach such temperature range. (0-400C).
Waiting for your kind reply.
Thank You
Regards
Amit Kumar
Hi Amit,
Note: there was a bug in my last post with ADC range of the plot being 2047 instead of 4095 counts. It should be now corrected.
That seems excessive. That sensor is only rated to 300C max. Do you really want or need this?I am expecting temperature range from 0-400 degree C.
I don't understand what you are saying. Are you measuring actual temperature with a thermometer? If you set the setpoint to 4096 ADC counts then the heater should stay on 100% and there should be no limit to the Temperature by KNozz.And i am getting temperature from 25 degree C to 287 degree C.
That has to do with your system and the Nozzle heater.And What voltage and current powersupply should I use to reach such temperature (0-400C).
4096 would apply power 100% of the time.What ADC count is required to reach such temperature range. (0-400C)
To get better resolution at such high temperature you could switch to higher resistance sensor such as the 105GT2. Or you could reduce the 10K reference resistor on KNozz by placing a 1K ohm resistor in parallel with the on-board 10K ohm resistor (connect from the Thermistor to GND). That should result in a plot like this:And how to increase resolution for thermistor calibration
Attachment 394502
The resolution at 300C is ~ 1/4 degree C. See also the attached spreadsheet. Note the curve fit is now made over more of the high range and provides a better fit of the high range.
Regards
TK
Hi Tom,
Yes i need this.That seems excessive. That sensor is only rated to 300C max. Do you really want or need this?
Yes i am measuring the actual temperature with thermometerI don't understand what you are saying. Are you measuring actual temperature with a thermometer?
Regards[/QUOTE]
I tried the curve fitting method also but the curve i want to fit is 6th order polynomial so in KnozzMcodeTemp file what changes are required. When i am inputing 6th order polynomial in mcode file i am getting negative counts and negative temperature. How to correct this ? or implement 6th order inverse polynomial to solve ADCtoTemp() function inside that mcode file for 6th order polynomial equation.
Thank You
Regards
Amit Kumar
Hi Amit,
Change:I tried the curve fitting method also but the curve i want to fit is 6th order polynomial so in KnozzMcodeTemp file what changes are required.
Code:// function to convert Temp C to ADC counts float TempToADC(float T) { return ((-0.000837 * T + 0.170202) * T + 4.565045) * T + 78.452228; // 3rd order polynomial }
To:
Code:// function to convert Temp C to ADC counts float TempToADC(float T) { #define c6 0.0000 // 6th order coefficients #define c5 0.0000 #define c4 0.0000 #define c3 -0.000837 #define c2 0.170202 #define c1 4.565045 #define c0 78.452228 return (((((c6*T+c5)*T+c4)*T+c3)*T+c2)*T+c1)*T+c0; // 6rd order polynomial }You would need to show us what you did.When i am inputing 6th order polynomial in mcode file i am getting negative counts and negative temperature. How to correct this ?
The numerical inverse solution should still work with a 6th order equation if it is well behaved. You might need to change the initial guesses to be over your range. change:or implement 6th order inverse polynomial to solve ADCtoTemp() function inside that mcode file for 6th order polynomial equation.
float A, T, T0 = 0.0, T1 = 100.0; // initial guess 0 and 1
to
float A, T, T0 =50.0, T1 = 400.0; // initial guess 0 and 1
In cases like this I always remember John von Neumann famously said:
With four parameters I can fit an elephant, and with five I can make him wiggle his trunk.
HTH
Regards
TK
Hi tom,
I am using Knozz board connected with kflop board.
I have connected thermistor Semitec 104GT2 100K ohm thermistor.
When is set the temperature of 200 degrees using m code i am not getting exact temperature. as you said it is 1degree accurate.
How to make it temperature and ADC count graph value accurate. ?
Or i have studied PID temperature control used by arduino board. Proportional Integrative Derivative (PID) Based temperature control is accurate but it is not available with current Knozz Board.
https://www.eurotherm.com/pid-control-made-easy
Above link explains PID based temperature control.
How to implement PID settings into Knozz Board.
Waiting for positive response.
Thank you
AMIT KUMAR
Regards
Amit Kumar
Hi Amit,
In my previous email I asked:When is set the temperature of 200 degrees using m code i am not getting exact temperature. as you said it is 1degree accurate.
You never responded. Have you done this?
Regards
TK
Hi Amit,
What did you do? What happens?
Regards
TK
Hi Tom,
Yes i had done this placing 1k ohm in parallel with the on-board 10K ohm resistor. So the total resistance with become 909.09ohm.To get better resolution at such high temperature you could switch to higher resistance sensor such as the 105GT2. Or you could reduce the 10K reference resistor on KNozz by placing a 1K ohm resistor in parallel with the on-board 10K ohm resistor (connect from the Thermistor to GND).
And yes i tested using the above setup but still i am getting wrong values in very high temperature.
How do i solve this.
Regards
Amit Kumar
Hi Amit,
Test your hardware. Create a table of ADC counts and actual measured temperature. Post it here.
Regards
TK
