Hi Amit,
What kind of Nozzle and Bed Heaters do you have? What kind of Thermistors?
Here is a link for the connector wiring:
KNozz Connector Descriptions
Some info on our wiki:
How to convert a milling machine to a 3D printer in 3 easy steps - Dynomotion
Attachment 375858
Here is a example C Program to monitor and control heater temperatures. Set Points are expected to be in KFLOP Persist Variables (default is 30 and 31) and can be set by a KMotionCNC MCode with P and Q parameters for the Nozzle and Bed. Configure a KMotionCNC MCode such as M101 with a do nothing C Program and Var of 30. You must also calibrate your Thermister and create a function TempToADC() to convert degrees C to ADC counts. The C Program It is also attached as a txt file.
Code:
#include "KMotionDef.h"
// This program services KNozz to read the two KNozz ADCs and
// control two heaters based on a pair of Persist Variable Setpoints
// The consecutive Persist variables correspond to the Nozzle and Bed Setpoints
// A KMotionCNC MCode can be configured to set the temperature setpoints
// using P and Q parameters. ie.
// M100 P100 Q50 (Set Nozzle and Bed temperature setpoints)
#define AUX 1 // 0=Aux0 1=Aux1 defines which Aux connector to use.
// define pair of persist variables (as floats) as heater setpoints
#define NOZ_VAR 30
#define BED_VAR (NOZ_VAR+1)
//SPI and Heater IO definitions
#define CS (23 + AUX*10)
#define DATAIN (24 + AUX*10) // with respect to KFLOP
#define CLK (25 + AUX*10)
#define DOUT (22 + AUX*10) // with respect to KFLOP
#define NOZ_HEAT (21 + AUX*10)
#define BED_HEAT (20 + AUX*10)
int SPI_IN(int send_data); // function to read serial SPI dual ADC
float TempToADC(float T); // function to convert Temp C to ADC counts
float ADCtoTemp(float At);// Solve inverse function numerically using guesses and linear interpolate
void ServiceKNozz(void); // Service KNozz Temperature controls
float *NozSetPoint = (float *)&persist.UserData[NOZ_VAR]; // define convienient pointers to Persist floats
float *BedSetPoint = (float *)&persist.UserData[BED_VAR];
main()
SetBitDirection(CS, 1);
SetBitDirection(CLK, 1);
SetBitDirection(NOZ_HEAT, 1);
SetBitDirection(DOUT, 1);
SetBitDirection(BED_HEAT, 1);
*NozSetPoint = 0; // start with heaters off
*BedSetPoint = 0;
for (;;)
Delay_sec(0.001); // loop ~every millisecond
ServiceKNozz();
static int JobWasActive = FALSE;
static int i = 0;
int raw_counts_bed = SPI_IN(0xf000); // Read ADCs
int raw_counts_noz = SPI_IN(0xd000);
if (i++ >= 1000) // diagnostic printout ~ every 1 sec
i = 0;
printf("Nozz:Setpt %6.1fC %6.1fcnts Actual %6.1fC %4dcnts Bed:Setpt %6.1fC %6.1fcnts Actual %6.1fC %4dcnts\n",
*NozSetPoint, TempToADC(*NozSetPoint), ADCtoTemp(raw_counts_noz), raw_counts_noz,
*BedSetPoint, TempToADC(*BedSetPoint), ADCtoTemp(raw_counts_bed), raw_counts_bed);
if (raw_counts_noz < TempToADC(*NozSetPoint))
SetBit(NOZ_HEAT);
else
ClearBit(NOZ_HEAT);
if (raw_counts_bed < TempToADC(*BedSetPoint))
SetBit(BED_HEAT);
else
ClearBit(BED_HEAT);
if (JobWasActive && !JOB_ACTIVE) // Job Stopped?
// *NozSetPoint=0; // yes, turn off heater?
// *BedSetPoint=0;
JobWasActive = JOB_ACTIVE;
void Dly(void)
Delay_sec(5e-6);
int i;
int dataIn = 0;
SetBit(CS); //CS high
Dly();
ClearBit(CLK); //CLK low
Dly();
ClearBit(CS); //CS low
SetStateBit(DOUT, (send_data >> 15) & 1);
Dly();
for (i = 0; i < 16; i++)
SetBit(CLK); //CLK high
Dly();
dataIn = (dataIn << 1) | ReadBit(DATAIN); // read the bit
SetStateBit(DOUT, (send_data >> (14 - i)) & 1);
Dly();
Dly();
return dataIn;
// Convert Temperature in C to equivalent ADC Counts
// based on 3rd order data fit to this measured data
// Temp C, ADC
// 16.0 199
// 35.0 400
// 49.1 600
// 54.7 700
// 60.7 800
// 66.9 900
// 73.6 1000
// 78.4 1100
// 85.2 1200
// 93.8 1300
//107.5 1482
//115.5 1570
//125.0 1688
//132.0 1722
return ((-0.000837 * T + 0.170202) * T + 4.565045) * T + 78.452228; // 3rd order polynomial
int i;
float A, T, T0 = 0.0, T1 = 100.0; // initial guess 0 snd 1
float A0 = TempToADC(T0); // see how well they did
float A1 = TempToADC(T1);
for (i = 0; i < 10; i++)
// linearly interpolate
T = T0 + (T1 - T0) * (At - A0) / (A1 - A0);
A = TempToADC(T); // check how well it works
// printf("Desired ADC %f guess Temp %f ADC %f\n",At,T,A);
if (fast_fabs(A - At) < 0.1f) break; // good result exit
// replace furthest away guess with new result
if (fast_fabs(A - A0) > fast_fabs(A - A1))
T0 = T;// replace guess #0
A0 = A;
else
T1 = T;// replace guess #1
A1 = A;
return T;
HTH
Regards
