585,978 active members*
4,430 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Citizen cincom B12 449 A3 Axis: inv. IPM Alarm
    Sep 2017
    Unhappy Citizen cincom B12 449 A3 Axis: inv. IPM Alarm
    hi i'm new here
    I live in Costa Rica and have a problem with the alarm IPM 449 on the A3 axis (subspindle) on the servo amplifier display appears the letter A.
    How can i fix it?
    Nov 2014
    26
    Re: Citizen cincom B12 449 A3 Axis: inv. IPM Alarm
    Letter A on the servo drive is a parameter has been set wrong
    Aug 2006
    162
    ipm is intelegent power module(or something to that effect) it monitors current and voltage applied to the motor. alarm on the drive will be either a,8,9 it tells you which axis is affected. i have been told most common problem is motor power cable, followed by motor, finally amplifer. i have attaced a link to an article that gives a basic trouble shooting explanation. the information i have is for tsugamis so the axis's wont match up
    Quick Guide for Fanuc System Troubleshooting: Is it the Cable, the Amplifier, or the Servo Motor?
  1. cincom citizen L20/3M7
    By mustijo in forum CITIZEN Machines
    Last Post: 02-01-2019, 11:20 PM
  2. Citizen Cincom L16
    By steelway in forum CITIZEN Machines
    Last Post: 02-01-2019, 11:08 PM
  3. C-AXIS PARAMETERS for Citizen Cincom F20 CNC Lathe
    By Artifol in forum CNC Swiss Screw Machines
    Last Post: 12-15-2015, 08:50 AM
  4. C-AXIS PARAMETERS for Citizen Cincom F20 CNC Lathe?
    Last Post: 12-08-2015, 05:40 AM
  5. Citizen Cincom e32
    By patycoop in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-30-2012, 04:13 AM
