585,604 active members*
3,541 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > why is this moving in such small steps?
    Nov 2016
    5
    please see the attached video.
    this is a home built machine using grbl. sketch was made on fusion 360. its arabic text extruded.
    the machine seeks at good speed but when it comes to cutting it moves in VERY small steps. I just need to know the parameter responsible for this. is it in the drawing or in the GRBL settings?
    any help would be much appreciated.
    thank you.
    https://youtu.be/grK06HCHbDQ
    https://youtu.be/FxWdsXTIA2k
    Sep 2013
    Re: why is this moving in such small steps?
    i havee the same problem
    i have sinumeric 810
    what's yours control?
    i read about insert G64 at the begining code but does'nt works for me
    Sep 2006
    245
    The slowdown might be related to many small straight line segments used to create the image. I don't know what controller you are using, but maybe these things can help you.
    Can you change the image to produce larger line segments? It rarely needs as many small segments that some software can produce.
    The Mach3 controller has a choice between "constant velocity" or "exact stop" modes. In exact stop mode, it stops completely between every line segment. Switching to constant velocity lets it stay at full speed as much as possible.
    Mach3 also slows down considerably if backlash compensation is turned on and there are many tiny segments.
    Steve
    Nov 2016
    5
    Quote Originally Posted by tazt View Post
    hello
    sorry for the very late reply
    in case you havent solved your problem yet, mine turned out to be a fairly simple solution. It turned out that I was setting a very slow cutting speed when exporting the gcode. I use Fusion 360, and had accidentally set the feedrate to 1mm/min! Changed that to 1000mm/min and now it runs like it should.
    hope this helps!
  1. Axis moving too far, to many steps.
    By Snake045 in forum Mach Mill
    Last Post: 05-21-2016, 10:41 PM
  2. MOVING TORMACH 1100 DOWN STEPS
    By keen in forum Tormach Personal CNC Mill
    Last Post: 05-17-2015, 03:56 AM
  3. stepper loses steps then stops moving all together
    By sirknight in forum Gecko Drives
    Last Post: 03-30-2014, 02:11 PM
  4. TS-4060-H80 losing steps on X when speed moving
    By tcarita in forum Chinese Machines
    Last Post: 02-07-2013, 04:36 AM
  5. Replies: 1
    Last Post: 09-20-2012, 10:23 AM
