585,931 active members*
5,468 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Problem with printing out tool lists and run times
    Oct 2017
    Long time (20 years) Surfcam user. Had a virus last week and now can't get the tool list and machining times to pop up so I can print them out. It acts like it is doing something, but nothing happens.
    The printing function of the main screen and the posts are working just fine. Same problem with current version and all of the older versions, I checked. Any thoughts?
    Nov 2008
    Re: Problem with printing out tool lists and run times
    Hi
    I think you have a problem with your web browser. This tool list open operations.cfg in your default browser.
    May 2014
    11
    Try changing the setup sheet style to classic - this is text only output - should confirm if it's an issue with your internet browser.
    Tools>Options>Files>Setup Sheet
  1. Improving cycle times on tool paths
    By hitatchisekidan in forum GibbsCAM
    Last Post: 04-13-2016, 06:41 PM
  2. Tool Library.... good times.
    By photomankc in forum SprutCAM
    Last Post: 02-17-2015, 05:01 AM
  3. Tool times
    By MDUB in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-05-2014, 08:59 PM
  4. Need some tool lists of whats in your tool box, and what you cant live without
    By NoGoodNolan in forum Maintenance DIY Discussion
    Last Post: 10-11-2014, 10:10 PM
  5. Tool table lists 200 tool #'s. How do I assign these?
    By Manny Machado in forum Haas Mills
    Last Post: 10-20-2013, 02:44 AM
