585,555 active members*
3,008 visitors online*
    Jul 2017
    12
    Buffer Problem !
    Hi there !
    I' m getting a "Buffer Problem" message when I' m runninh my g-code.
    What is the most probabe cause of this "Buffer Problem"
    1. CAM software
    2. Computer
    3. Controller in particular
    4. Program in G-code
    Any help from a newbie will be greatly appreciated.
    Jun 2015
    119
    Re: Buffer Problem !
    It would help to know what kind of machine, where you are running the code from, how you generated the code, that sort of thing. But, as a guess, you are running code that has too many strokes per minute (too many very small moves), which is causing the buffer to be starved for information, because it can't process fast enough.
    ____________________________
    My blog: http://www.fletch1.com
    Jul 2017
    12
    Quote Originally Posted by Fletch_CNC View Post
    i' m usinc cnc-usb firmware, artcam2018 to make toolpath and generate g-code. using a china made 6040 router doing some relief arts.
    thanks
    Jun 2015
    119
    I'm not sure what "relief arts" are, but I imagine it involves lots of tiny moves. You might see if you can get your software to output longer moves, instead of lots of tiny ones. I am not familiar with Artcam, so i can't say where that would be. In Mastercam, the Tolerance setting would control how tight the toolpath is.
    Is it possible to increase the size of your buffer?
    To test if it is a problem with simply having too many moves for the control to process, try cranking the feedrate down to almost nothing, and run the program. You don't have to cut anything, just let it run and see if you still get the buffer error.
  1. Coordination Buffer Problem?? Ver. 433k: How to set in Dot.net...?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-19-2015, 09:03 PM
  2. Buffer Hp Help
    By jonkzak in forum MetalWork Discussion
    Last Post: 11-05-2014, 03:50 PM
  3. HAAS VF2 DNC buffer problem
    By mmodeler in forum Haas Mills
    Last Post: 05-28-2009, 12:11 AM
  4. DNC-Buffer overload problem
    By Fish in forum DNC Problems and Solutions
    Last Post: 07-18-2005, 05:52 PM
