585,763 active members*
4,069 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > How to geometry setting in the Hyundai HIT 15 lathe
    Jun 2015
    46
    Hello I have a problem in my Hit 15 lathe. The drill is not in centre when I try to driling. The carbide tool was broke.
    When I go to X=0 I can see the drill tool are a litle upper than axis... Not in X but in other axis which I can not change in offsets. How I can repair it?
    Jun 2015
    46
    Re: How to geometry setting in the Hyundai HIT 15 lathe
    I lose this nuts (red rings on the photo), next I remove cilindrical fixing pins, and tool head not move. All the time I have around 0,4 mm deviation. The head is a little uper than should.
    I lose this 12 nuts under this black cap but there are only splines. Maybe somebody can help me?
    Aug 2008
    93
    Problem is not with the splines. You are correct to loosen the 12 bolts in the red circles and the pins. You will need to hit the turret with a soft face hammer to align it. When correct, you will need to ream the 8mm taper pin holes back to true zero and put in new pins. The 12 bolts in the center around the splines are a safety slip clutch if the turret would crash when it is in the out/unlocked position.
    Aug 2008
    93
    I will add, on my lathe the ID tool holders are not a tight fit to the turret, They have some play and you can move the point of a drill up and down a little bit if you loosen the 4 bolts that hold the holder to the turret.
    Jun 2015
    46
    Thank you for answers. I tryed losethe nuts and set the correct position, but this head stood... I have to try again.
  1. Hyundai LMC400 CNC lathe
    By trxryan in forum Hyundai Kia
    Last Post: 08-17-2016, 10:20 PM
  2. setting Z0 and tool Z0 geometry offsets
    By pleasedontcrash in forum CNC Swiss Screw Machines
    Last Post: 05-15-2015, 11:32 PM
  3. Hyundai hit 30s cnc lathe purchase
    By weldthis in forum Hyundai Kia
    Last Post: 09-19-2014, 02:40 PM
  4. Hyundai HiT-18S CNC Lathe
    By Clutchbone in forum Hyundai Kia
    Last Post: 06-19-2014, 09:23 PM
  5. Geometry from NC 3D Setting
    By Kiwi in forum BobCad-Cam
    Last Post: 07-18-2006, 01:29 PM
