585,727 active members*
3,927 visitors online*
    Oct 2017
    Mach3 on cnc punch
    Hi everyone.
    I have a retrofitted cnc punch with Mach3,and i have problem running gcode from cnckad cad cam software on mach3.
    Any advise about how to run gcodes for punch press on mach3?or how to edit post processor file from cnckad to run on mach3?
    Appreciate your help
    24220
    Re: Mach3 on cnc punch
    Thread moved to Mach forum.
    Al.
    Albert E.
    24220
    I assume you have X - Y part positioning hardware in place, if so it is usually a easy task of positioning material in the X & Y and then issue the M code to trigger the punch.
    Al.
    Albert E.
    Oct 2017
    Al.
    When i enter X Y axis coordinates in the gcode the table moves but away from the punch ram,how can i adjust the machine coordinates?
    What is the m code to trigger the punch?
    Thank you for your help.
    Feb 2016
    5
    Hi, Anyone can help share post processor(machines file) for Amada 355 in cncKad software? help and email to: [email protected] .thks
  1. cnckad punch off the table euromac BX1000 top punch
    By renatomail in forum Post Processor Files
    Last Post: 10-19-2017, 11:55 AM
  2. Mach3 Punch Press Screen Needed
    By Brainfreeze in forum Screen Layouts, Post Processors & Misc
    Last Post: 06-22-2013, 07:00 AM
  3. punch tooling,cnc punch press tooling
    By sentool in forum News Announcements
    Last Post: 10-04-2011, 04:26 AM
  4. Punch?? or What??
    By ShayArnett in forum MetalWork Discussion
    Last Post: 03-20-2010, 03:28 AM
