585,712 active members*
4,198 visitors online*
    Sep 2017
    6
    tool path help
    i am creating a tool path to finish round the outside of the component but hypermill calcutes one for the inside also, how can i stop this?
    Aug 2008
    Re: tool path help
    Hi Mr Radcliffe1978
    Looks like your using a Z Level finishing cycle to get that toolpath?
    if so :-
    You could cap the hole to stop it dropping in and add this surface to the additional surface area found in the setup page of the z lev cycle
    or
    You could add an inner and outer boundary. hyperMILL works by finding every thing on the inside of the boundary and then the inner boundary is not allowing a toolpath inside. If you don't have any boundary it will cut everything
    or
    You could pick just the surfaces you want to machine - found in the boundary page > milling surfaces
    Why don't you call support in UK 01869 290003, many ways to solve this easily if its not z lev finishing cycle.
    Best of luck
    u can use boundry, or u can add stop surface, or u selected tool status past,or, inside.
  1. Software/ Online tool to modify G-code for unidirectional 'Zig tool path'
    By eeu23b in forum Uncategorised CAM Discussion
    Last Post: 09-13-2017, 07:12 PM
  2. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  3. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  4. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
