I have a Vectrax MSC Centroid M-15 knee mill that I would like to modify the quill to function as the X & Y axis in "free" mode. I realize the only way to make that hapen is to replace the rotary encoder with a 6" glass scale. Tha z axis kit is an early Elrod design, and by drilling a 1/4" access hole that lines up with the ball nut housing clamp screw when at the bottom of travel, I can free the nut from the clamp housing and have a freed quill. With the glass scale reader head attached to the clamp housing I should "theoretically" have a manual Z dro like the X & Y if there is a way to go into setup and activate a Z axis free command. Is this possible?
Thanks for any help,
Woody
