585,758 active members*
4,329 visitors online*
Results 1 to 6 of 6
    Mar 2008
    82
    Window cleaning
    What are y'all using to clean the lathe or mill glass windows? I tiered Windex but it didn't work really well. Its coolant splash predominantly.
    Jun 2014
    1780
    Re: Window cleaning
    I use rubbing alcohol to remove the residue from cutting wood, might give that a try........
    mike sr
    Mar 2009
    1863
    Re: Window cleaning
    Scrub it down with coolant then Windex it. The coolant will cut right the dried on stuff.
    That’s the way I clean mine.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Feb 2006
    7063
    Re: Window cleaning
    Some coolants actually attack the plastic (I sure hope it's not really glass!). If that's the problem you're having, then you CAN'T clean it, you have to replace it (and preferably find a better coolant).
    Regards,
    Ray L.
    Mar 2008
    82
    Re: Window cleaning
    Its the coolant that Torch supplies, so likely not going to attack the window?
    Thanks for all responses
    cleaning guide
    Quote Originally Posted by dannirr View Post
    we created a quick guide if your intrested: https://cncmachines.net/how-to-clean-your-cnc-machine/
  1. Block Window
    By kolias in forum Mastercam
    Last Post: 10-14-2013, 03:11 PM
  2. rotary window
    By SiCk_NaStY in forum Mori Seiki lathes
    Last Post: 07-14-2013, 09:19 PM
  3. CNC corner cleaning machine(pvc window machine)
    By DECA in forum News Announcements
    Last Post: 08-29-2012, 03:35 AM
  4. Mori NV5000 window glass cleaning
    By teal854t in forum Mori Seiki Mills
    Last Post: 09-12-2011, 10:52 PM
  5. MDI Window
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 11-20-2010, 02:34 AM
