Re: 2395 Alarm-B User Reserve code 92 ‘PROBE OPEN’
Probe open means that it is not communicating with the probe. Check the easy stuff. Battery, proper M-code for enabling, probe settings. The alarm is a user generated alarm, so it is defined inside the probing macro or MSB file. Searching through the macro may give more info as to what is triggering it, but I think it will just say basically what I did...not communicating.
If this is a new machine, the macros should be listed in the Gauging instruction manual and will usually even show the macros being used listed in the manual.
Best regards,
Experience is what you get just after you needed it.
