Hello again.
Can you give me a bit of advise?
I'm cutting 9mm MDF with 3 passes for a logo protect. When its finished, there are 2 lines showing on the edge (from the separate passes). I can sand them out but its quite time consuming.
I saw the feature that lets the last pass have a separate offset, so I made it 0.2 and its definitely better, but still not a clean flat edge.
Will the additional 'reverse on last pass' function improve this?
Thanks.
