586,005 active members*
4,974 visitors online*
    Dec 2005
    141
    HELP! Need Help Removing Servo
    I need to remove a Y Axis from a VMC, and i do not know how motor coupling comes apart.
    The machine is a Vulcan which is a rebranded Kasahara
    Here are some pictures of the motor coupling
    Attachment 376976
    Attachment 376978
    Attachment 376980
    You can see a collar that is loose, that is just a collar... dont know what it does,
    I also tried to remove the other set of nuts and they just spin...
    I cant believe that it is this hard to replace a servo?
    Any Suggestions?
    Mar 2008
    683
    Re: HELP! Need Help Removing Servo
    It looks like a QD bushing / coupler that just might be stuck on the shaft of the ball screw. I can't really see 100%. Judging by the rust the shaft is just rusted to the coupler. It looks like it may need heated up a bit to expand the female side of the coupler. But just be very careful you aren't going to burn anything.
    Take a look at the catalogs and you can see how they work.
    GGMFG > Products > Couplers/Clutches > Coupler Hubs
    https://www.mdsofmi.com/product-cate...s/bushings/qd/
    https://www.youtube.com/watch?v=_7zWbKRsh04
    24221
    That is identical to to a Rexnord Type SN single flexible disc coupling.
    Usually each side is keyed on.
    Google Rexnord Cat #2000 Page #46
    Al.
    Albert E.
    Dec 2005
    141
    Thanks guy!
  1. removing spaces
    By blakey235 in forum EdgeCam
    Last Post: 05-20-2014, 03:32 PM
  2. Help removing servo coupler
    By jfong in forum Maintenance DIY Discussion
    Last Post: 01-27-2014, 06:34 PM
  3. Removing USB safely.
    By scrapper400 in forum HURCO
    Last Post: 01-30-2011, 12:14 AM
  4. X2 - Removing the R8 Spindle
    By webgeek in forum Benchtop Machines
    Last Post: 04-03-2010, 06:28 PM
  5. Removing the armature ?
    By Ken_Shea in forum Servo Drives
    Last Post: 10-10-2005, 08:40 PM
