585,975 active members*
4,568 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Mill tapers: aprox cutter and materials for ISO10, ISO15, ISO20
    Dec 2005
    436
    re: ISO10, ISO15, ISO20
    Does anyone know about the capacities of these tapers?
    Lets say for steel, cold rolled and O1, what size cutters and feeds are these tapers designed for?
    I know it also depends on the machine and lots of other factors, but nominally, is there any info out there, or anyone with experience??
    Jun 2007
    47
    Re: Mill tapers: aprox cutter and materials for ISO10, ISO15, ISO20
    Quote Originally Posted by cncuser1 View Post
    Don't know about the larger 2, but ISO 10 typically uses er16 collects which top out at 3/8" or 11mm.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Sep 2006
    6463
    Hi, I have IS0 20 on my Skyfire SVM-0 mill and tool holders with ER32 chucks.
    You can also get ISO 20 tool holders with ER20 on EBAY rated to 30,000rpm.
    Ian.
    Dec 2005
    436
    For cutting steel, I was wondering what type of material removal( depth of cut, feed speeds, cutter dia., etc) is typical for each size?
    Yeah I know there are many factors, but ballpark what can Ii assume when making a decision on what to commit to>?
    - - - Updated - - -
  1. Suggested materials to use for laser cutter's outer and interior walls or panels
    By Dan-Tron in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-15-2017, 06:49 AM
  2. BT15/ISO15 and BT20/ISO20 Spindle Cartridges.
    By dwalsh62 in forum News Announcements
    Last Post: 08-31-2013, 12:56 PM
  3. ISO20, ISO30, HSK 50 HSK 63????
    By 15mgtar in forum CNC Tooling
    Last Post: 08-21-2010, 02:25 PM
  4. ISO15 taper dimensions
    By cncuser1 in forum CNC Tooling
    Last Post: 10-09-2007, 12:13 AM
