Hi All
I have been asked to assist a UK University in getting their NM-200 up and running properly.
We will be working through the electronics at some point as they wanted to install a SmoothStepper and that is giving them some grief.
The more important question for me though is the head nod.
I have trammed the head in the X direction fine. But the Y is low on the front of the machine.
Use a dial test indicator as well as my trust Edge Tech. trammer.
The Z axis is spot on perpendicular to the bed as I use a granite square to see if the column was out.
The only way I can think of fixing this is by shimming between the swivel plate and the box that the linear carriages screw in to.
Any other ideas?
If this is the only way, how do I pull the head away enough to sneak the shim between the parts?
Thanks in advance guys.
