585,962 active members*
3,939 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Modelling Tools for Shadow Board Foam
    Feb 2012
    I am about to start designing the layout files for tool control foam shadowboards which will go in the drawers of a Pelican 0450 mobile tool chest. I have a good idea of what tools I will be putting in each drawer and how I want to lay them out, but I’m wondering how to go about scanning/modelling the tools in SW for the laser cutting company to make the inserts. The box will have some tools with quite complex shapes. Spanners, pliers, wire strippers and cutters to name but a few. Does anyone have experience of modelling for this sort of thing?
    Dec 2013
    5717
    Re: Modelling Tools for Shadow Board Foam
    If you have a scanner or a digital camera. Scan or take a picture of the tool to get the outline, import the picture into your CAD program, sketch the outline around the picture. Once you do that then scale the sketch to some known dimension on the tool.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2010
    What I would do is take a picture of your tools how you want them laid out in your tool box then import them into Adobe Illustrator, then use the pen tool to create vector lines then your should be able to import them into your laser machine. I have done this a few times.
  1. Replies: 0
    Last Post: 11-26-2015, 10:34 PM
  2. Tool Shadow Board Software
    By IQChallenged in forum Uncategorised CAD Discussion
    Last Post: 11-05-2014, 02:41 PM
  3. Milling foam rubber - which tools ?
    By cncvirgin in forum Material Machining Solutions
    Last Post: 10-24-2014, 04:42 AM
  4. Rust shadow on mill table and some CAT40 tools - how to remove?
    By helocat in forum Uncategorised MetalWorking Machines
    Last Post: 12-20-2011, 04:40 PM
