585,962 active members*
3,640 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Aluminium Round, OD Grooved, through hole + c'bore - NSW
    Nov 2017
    Hi guys, is there anyone currently out there that can make 6 off these parts? Either from 6061 or similar material. The OD is 63.19mm. Details on the features in the description can be provided if needed, just after a ballpark figure of what it would cost. Would it be any cheaper if I supplied the material. Thanks in advance.
    Re: Aluminium Round, OD Grooved, through hole + c'bore - NSW
    Hi,It can be cut into 6 pieces. I can cut it here by wire cutting machinesPlease contact me [email protected]
    Cheers!
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
  1. Bore tapered hole
    By DavidhCNC in forum BobCad-Cam
    Last Post: 03-17-2016, 01:28 PM
  2. Replies: 5
    Last Post: 08-07-2014, 05:12 AM
  3. Oversized Pulley Bore Hole
    By JustinLiang in forum Mechanical Calculations/Engineering Design
    Last Post: 12-06-2013, 10:55 AM
  4. How do I bore a hole with V25 lathe?
    By mbam in forum BobCad-Cam
    Last Post: 04-29-2013, 03:08 PM
  5. Helix Bore's - hole sizes not right
    By kprice1658 in forum Mastercam
    Last Post: 01-31-2010, 05:46 PM
