585,970 active members*
4,364 visitors online*
Results 1 to 14 of 14
    Nov 2017
    9
    Need help with vmc760
    I am new to the forum. I just got my 1996 Bridgeport VMC760 22 under power. Every thing works but I do have a (spindle not up to speed in time) alarm. The spindle oscillates for about 5 sec. Any pointers would be great. I have no problem getting my hands dirty. Thanks
    Dec 2013
    5717
    Re: Need help with vmc760
    Is it possible that the spindle is cold and needs to warm up a bit before you bring it up to cutting speed? Maybe lubrication?
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2009
    6028
    Since its a new to you install, I'd guess incoming power issue or possible reversed phase depending on spindle drive type and control.
    Sent from my SM-T813 using Tapatalk
    Nov 2017
    9
    I have 208 3 phase. I have not check the phase rotation with a gauge yet. I think it is correct because the tool carousel is depending on correct rotation and that work as it should. I can not get the spindle to spin at all with any command. M03 or M04 and if I give it M19 It will just continue to oscillate but will not alarm out with a M19. Thanks
    Dec 2013
    5717
    208 could be the problem. Is the machine wired for 230? Is there a transformer that has different taps to adjust the voltage to the spindle?
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    9
    yes there is a transformer with a 200-210 post.
    Dec 2013
    5717
    That might fix it.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    9
    The spindle load is 160% when it is oscillating. Does it have a brake on the spindle? The spindle spins free by hand.
    Feb 2009
    6028
    A few things cause this, but if you keep just trying to start it, you will blow the spindle drive, if not already.
    You have yet to give info on control type, spindle drive type etc, so kinda hard to help.
    1. Voltage
    2. Spindle trying to start in the wrong direction
    3. Velocity Feedback system for the spindle/motor not working.
    4. Blown transistors in the spindle drive.
    Nov 2017
    9
    I have wires connected to the 200-210 voltage tap already.
    Nov 2017
    9
    Sorry DX32 control and siemens drive
    Nov 2017
    9
    Just an update my spindle logic board was the problem. I did notice something if you stop the spindle with the stop key it will alarm out. (spindle not up to speed in time). M19 will orientate the spindle just fine. Any info on the would be great. Thanks
    if spindle is oscillating a bit on orientation around encoder index flag m19 then parameters in bmdc may not tuned...correctly which gives not up to speed error < velocity sample rate etc.......><spindle gain> maxspeed etc or the 611 drive params can get messed if touching the simo drive
    Nov 2017
    9
    Quote Originally Posted by service_75 View Post
    Thanks for the reply. I found that by spindle drift with the spindle command of 0 rpm was way off it was -18 RPM so I adjusted the spindle drive accordingly. Everything works perfectly now.
  1. bridgeport vmc760/22 manual
    By [email protected] in forum Machinery Manuals / Brochures
    Last Post: 12-29-2014, 01:15 AM
  2. bridgport vmc760/22 password
    By [email protected] in forum Bridgeport / Hardinge Mills
    Last Post: 12-12-2014, 04:17 AM
  3. Bridgeport VMC760/22
    By chatrinder in forum Bridgeport / Hardinge Mills
    Last Post: 03-21-2012, 10:46 PM
  4. VMC760 Toolholder falling out!
    By snowygrouch in forum Bridgeport / Hardinge Mills
    Last Post: 01-24-2011, 05:10 PM
  5. Fault on VMC760
    By RadlandRobotics in forum Tree
    Last Post: 09-17-2010, 02:46 AM
