Hi
My 50w laser machine had been working perfectly until the power supply died, I have since bought 2 new power supply's and have 2 working tubes. The below is the results i get when engraving, cutting seems to be running perfect.
Chinese SH-350 50w laser machine
2 x tubes ( 85cm and 100cm ) and both power supply's that are working are 50W.
I have aligned mirrors, I've tried 2 lenses in case 1 had issues all with the same results, I've checked all belts and no settings had been changed on the software.
I'm out of ideas as to what might be causing this issue but it seems the laser isn't firing at the very start of each pass.
Any help or suggestions would be much appreciated
