I have a 6030 with a servo turret. It takes a few throws of the main power switch to get the machine to completely energize. The first one or two will not power the amps or the monitor, and you don't hear that air solenoid
activate while holding in the green push button. After it comes up, it can CS but comes up with a turret failure. Turret reverse relay(CR11) is lit, as is the ice cube at K5. I checked the fuses on it's amp and both good. meggered the
motor-good, but power is not getting to it. Checked boards for 120,5 and 12 volts, all good. Appreciate any help.
