585,932 active members*
3,856 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Gecko G540 + LinuxCNC parts are the wrong size
    Oct 2014
    10
    Just finished setting up linuxCNC and ran a code that I had used before and that I knew worked to test out the software. when I checked the dimensions of the part came out bigger and i cant figure out where the issue is .I've used the same Gecko drive and motors before with Grbl connected to an arduino so I know its not an issue with the electronics. Thanks for the help .
    Mar 2013
    140
    Re: Gecko G540 + LinuxCNC parts are the wrong size
    g540 uses a microstepping of 10, not 8
  1. My parts are coming out the wrong size!
    By bremerr in forum DIY CNC Router Table Machines
    Last Post: 12-18-2015, 04:43 PM
  2. Cnc parts cutting wrong size
    By o1jason in forum Stepcraft
    Last Post: 11-24-2014, 07:44 AM
  3. G540 cutting size wrong
    By Ed Williams in forum Gecko Drives
    Last Post: 10-30-2011, 01:53 AM
