584,860 active members*
5,231 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > Die cutting up to 1/4" aluminum: worth it to set up my own device?
Results 1 to 8 of 8
    Nov 2017
    4
    Greetings!
    I am an artist currently making chandeliers. I have this vision to weld together aluminum pieces to make large chandeliers. I have been dealing (or trying to deal) with Chinese manufacturers to have the pieces fabricated there and shipped to USA for me to assemble. There are about a thousand problems in these interactions, most deal with metal types, thicknesses, and metal qualities.
    It seems the best I can do is getting the items made in ZINC which is a terrible metal to weld mostly because I don't want to get cancer.
    New thought: buy a die press and make them all myself!
    Have a die made and I can hand-create each shape and have total control over my metals as well as a possibility to make endless shapes for very little continuing costs. Not only that, I don't have to deal with foreign language barriers, sub-standard product, shipping, customs, and all the waiting for my packages.
    Can you guys let me know if this is a viable idea?
    • I will be die-cutting aluminum from sheets up to 0.25 inches thick but no thicker than that
    • I will be using 6061 T4 or T6 grade aluminum
    • Each cut piece will not be larger than about 4 inches square
    I understand that many of these machines are kinda slow so it might take all day on the die cutting, but it would give me so much flexibility.
    The Questions
    1. Which machine is a good starter press for a metal die-cutting noob?
    2. Any businesses you would recommend to create the dies?
    3. Can I cut through aluminum that thick with a manual press?
    Thank you guys so much for your help! I like the idea of not outsourcing the pieces so I can say I made the whole thing.
    Apr 2004
    5728
    Re: Die cutting up to 1/4" aluminum: worth it to set up my own device?
    It takes a huge punch-press to die-cut 1/4" aluminum; it's not something most people have (or want) in their home shops. Have you considered sending the parts out to be cut with an abrasive water-jet machine? Plenty of shops do that here in the USA; you wouldn't have to deal with China. That would eliminate the cost of making dies; all you'd need to provide the shop would be DXF files for your shapes, which you could change all you wanted. I think you'd come out ahead financially. Here's a company (there are lots more) that will do it for you: Custom Abrasive Water Jet Machining & Cutting Services - Loveland, Ohio I suppose if you wanted to, and could afford it, you could buy one of these machines yourself, but I'm not sure the bragging rights would be worth it...
    Andrew Werby
    Website
    Dec 2013
    5717
    I agree with Andrew, pressing is not the answer. For low volume, constantly changing parts, the die costs would be crazy. Hundreds to thousands of $$$$$ per each die, and huge machines required.
    Water jet or plasma would be the best choice for what you want. I have cut 1/4 aluminum with my cheap Chinese hand plasma torch and have pleased with the cut quality. I suspect with a quality plasma torch that the cut quality would be better. A decent CNC plasma system can be had for < $10,000 new. I should set mine up some day.
    The other possibility is to use a CNC milling machine (not a router). Slower, but you have full control over the edge quality and well suited for low volume production.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    4
    That's what I figured. It would require too big of a machine to do it. I was guessing an initial order of about 300 pieces of each part and I'm trying to do it in a way that is quality yet still cost-effective. I'll check out the water cutting, but I really liked the CNC mill idea. Here is just one I found on ebay
    This is way more than I need, but I could do so much with it!!!
    Thanks for the ideas everybody! I'll keep doing my research.
    Dec 2013
    5717
    Quote Originally Posted by Dischg View Post
    That machine is way too light for what you want to do, it's a small CNC router/engraver, not a milling machine.
    I was thinking more like this for a CNC mill. https://www.ebay.com/itm/SuperMax-CN...AAAOSw7XBY8Toq
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    4
    Ahhhh bummer! I was looking at this cute little table top device thinking I could own the world without filling up my garage...
    But I get it. I'm rolling out hundreds of pieces. I should have something that can handle it. What if I was working on thinner aluminum? Something at 0.19" or 0.16"? .16 is pushing it, but it should be structurally sound once it's all welded together. Plus it will be so much lighter!
    Plus I only showed you a 4 axis unit that wouldn't be structurally rigid enough to do metals very well. If it was just a 3 axis unit, it could handle things better, no? This is still a new direction for me. I have a ton of work to do to figure this out.
    Dec 2013
    5717
    Those little tabletop machines are just not up to the task for any kind of production. You need a real machine.
    Here are some chandelier parts I built, about a week's worth of work. Probably more extensive machining than you would need to do on your parts. All sides needed some machining.
    And the machine I built them on
    And the setup on the table
    And the finished product. About 60 feet tall. I only built the aluminum parts, not the whole chandelier.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    4
    Now I'm both inspired and bummed...
    Inspired that your work IS SO INCREDIBLE! Bummed to see how extensive an operation I might need to DIY the whole project. Maybe I will go for the water cutting idea...
    I'm still down for the CNC mill, but I need to prototype first before I make the plunge.
    Thanks everyone for your advice. This is a real community here. I'm impressed!
    Rob, Seattle
  1. Cutting "Di-Bond" and .04in Aluminum Laminated to 12mm PVC
    By RossMosh in forum DIY CNC Router Table Machines
    Last Post: 12-07-2013, 11:46 PM
  2. Cutting 1" aluminum plate
    By RRedding in forum Charter Oak Automation Support Forum
    Last Post: 10-25-2012, 09:39 PM
  3. Cutting 1" sheets of aluminum.
    By Kalvin in forum Benchtop Machines
    Last Post: 05-07-2009, 05:32 AM
  4. Cutting 1/4" aluminum sheet
    By energyforce in forum MetalWork Discussion
    Last Post: 12-01-2005, 08:12 AM
