585,715 active members*
4,185 visitors online*
    Dec 2016
    10
    Overload axis Z, Mori Seiki
    Hello,
    I have the following problem in my machine Mori Seiki TV400, it seems that there is an overload in the Z axis servo, the alarms that appear are S52 00E1 and S03 0050, Could anyone help me?. Thank you very much
    Sep 2017
    139
    Re: Overload axis Z, Mori Seiki
    Have you sorted out the issue. E1 is an overload warning and 50 is overload alarm. Need to check the Z axis physically if its getting loaded due to mechanical issues or electrical.
    Dec 2016
    10
    I have not been able to solve the problem there is a procedure to disassemble the Z axis, in this type of machine?, where should I start ?. Thank you very much
  1. Mori Seiki SH 5000 not moves any axis
    By coldrex in forum Mori Seiki Mills
    Last Post: 08-23-2021, 08:30 AM
  2. Mori Seiki MV55 Z-axis thrust
    By samuelnolthoove in forum Mori Seiki Mills
    Last Post: 02-09-2015, 10:06 PM
  3. Mori Seiki MV-40 4th axis interlock.
    By GPena in forum Mori Seiki Mills
    Last Post: 08-20-2014, 03:04 PM
  4. Mori-Seiki X-axis cover
    By Chuck109 in forum Want To Buy...Need help!
    Last Post: 08-03-2011, 07:58 PM
  5. Mori Seiki Z axis Thrust Bearing
    By TWyatt9 in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2007, 03:25 PM
