586,005 active members*
4,932 visitors online*
IndustryArena Forum > CAM Software > EZ-CAM Solutions > In the Beginning--Bridgeport & EZ-CAM
    May 2006
    57
    Bridgeport and EZ-CAM dominated the market together, and EZ-CAM carried Bridgeport in the CNC arena. Bridgeport started in 1938 without a competitor in sight. Bridgeport mills fueled most every job shop right on up to every corporate enterprise. Even in its inception, EZ-CAM paired flawlessly with the early CNC controls. “EZ-CAM was feeding unimaginable amounts of code to every CNC machine Bridgeport could push out.” EZ-CAM changed the future of manufacturing. Accuracy, speed, and complex parts became attainable.
    EZ-CAM became famous through easy to grasp concepts and supported Bridgeport’s massive customer base. Soon, EZ-CAM expanded into the Turn and EDM markets. The need for a programmer to master G & M codes went by the wayside. At the click of a button, pages of code stand ready for your every machine.
    EZ-CAM increased functionality in Feature Recognition, Tool Based Machining, wizards, and the user interface. Feature Recognition automatically creates cutter paths. Tool Based machining loads your machining strategies after you select a tool. Wizards rid overwhelming and unnecessary clutter when programming complex shapes. The user interface is packed with keyboard shortcuts, and functions are easily identified graphically through eye-catching menu items.
    Mar 2007
    89
    Re: In the Beginning--Bridgeport & EZ-CAM
    In 1985 the shop I worked at bought EZ-CAM software on an Apple McIntosh. I loved it. I had to program a Bridgeport BOSS V control and a Heidenhain control. I modified the BOSS V post to create code to run the Heidenhain control. The program style worked exactly as my thought process. I never saw another seat of EZ-CAM after I left there.
  1. L10 start somewhere other than the beginning?
    By soundscu in forum WinCnc
    Last Post: 03-16-2016, 04:29 PM
  2. Beginning Mastercam Q&A
    By cadcam in forum Mastercam
    Last Post: 05-28-2012, 11:51 AM
  3. At the very beginning
    By rackbox in forum DIY CNC Router Table Machines
    Last Post: 12-01-2004, 11:56 PM
