585,914 active members*
3,685 visitors online*
    Nov 2017
    4
    Torch offset height help required
    Hi All.
    I’ve recently completed my plasma cutter CNC machine. I’ve managed to home it on Mach 3 and tuned the motors to etc.
    I’m a 3D design by trade so creating DXFs is not an issue. I’m stuck with getting the Torch end to raise up after it’s homed by touching the material surface.
    I believe this is in the code? Can someone point me in the right direction as to what to do next? Also are there any cheap or free g code generating programmes out there to get this machine to behave the way it’s supposed to.
    Many Thanks
    Sent from my Moto G (5) using Tapatalk
    Dec 2005
    160
    Re: Torch offset height help required
    I believe you need a macro for auto tool zero
    how to set up auto tool zero fot (X,Y,AND Z)
  1. Torch Height Offset Confusion?
    By Epiphany in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-02-2014, 01:23 PM
  2. How to set zero for torch height
    By kxkid in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-10-2013, 01:41 PM
  3. Torch Height ?
    By rtsplace in forum Hypertherm Plasma
    Last Post: 04-03-2011, 09:09 PM
  4. Required height for bringing in a Mazak VTC-41
    By Jcip in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-13-2008, 01:59 PM
  5. torch height help
    By marcmnrsports in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-01-2008, 07:45 PM
