585,974 active members*
4,219 visitors online*
Results 1 to 6 of 6
    Oct 2017
    USB Floppy Emulator with Windows 10
    We use a Greco Systems USB CNC Minifile for loading programs in machines. We use ipcas USB Floppy Emulator V1.31T with Windows 7 to load files on USB thumb drives. Our company recently upgraded our PC's to Windows 10 boxes and the software launches and recognizes the partitions on the thumb drive but will not open for viewing or drag & drop programs. Anyone have a Windows 10 USB Floppy Emulator working for them?
    Nov 2004
    164
    Re: USB Floppy Emulator with Windows 10
    I have the same issue the IPCAS software does not open the file manager to the partition for file management. I'm having to keep my old Windows7 box next to the new Win10 box just for file transfer to the USB stick for the floppy emulator. Did you find a solution?
    Oct 2017
    No, we have one old computer we are keeping for this. We did swap the floppy drive in a Cinc Lancer to a USB and it came with a pre-formatted thumb drive that says Haas on it, we can drag and drop files to it just using windows. They say a similar swap is available for our Toshiba HBM with Tosnuc 888. Our other vert mills don't have floppy drives, only the RS-232 port and still looking for a solution.
    Nov 2004
    164
    I did manage to get the IPCAS Floppy Manager v1.40 to work under Windows 10. I had to set the compatibility mode to Windows7 specifically. WindowsXPSP3 would not work. I also set it run as administrator for all users as well. I did this for Start menu shortcut and also every executable in the within the ipcas GmbH directory. Screen shot below:
    Year 2021 and another version of Windows 10 in the works.... The compatibility solution by JMullett seems to work, at least to a point. I have not been able to make a backup of the USB stick. I can select a directory to save the "floppies" to, but there is no way to select/create a backup file. However, creating the array of virtual floppies seems to work. Thanks for that
    Jul 2021
    My problem is that my disk was damaged, someone can help me to get them
  1. floppy to usb emulator help please
    By greggv in forum Haas Mills
    Last Post: 03-29-2016, 03:22 PM
  2. Floppy Emulator
    By ScottTheBruce in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-01-2015, 06:38 PM
  3. Floppy to usb emulator
    By MAN39ER in forum EDM Discussion General Topics
    Last Post: 09-25-2014, 10:40 PM
  4. Anyone using a USB / Floppy emulator?
    By JasonR in forum Haas Mills
    Last Post: 09-01-2014, 07:25 PM
