I am hoping this is a simple setting and I have accidentally set something. When I issue the command M3 S12000 in mach, my relay kicks in and the spindle starts to speed up. the VFD is displaying 120hz. In the Ethernet smooth stepper data monitoring, the ratio sets itself to .5 and the velocity is a hilarious number (5368709) If I issue M3 S24000, vfd still displays 120 hz. I would keep playing but yesterday I had some spindle setting incorrectly set and made a little bit of magic smoke from the main 4 pin spindle connector. Thankfully it was already in the process of shutting down and I did a factory reset to start from scratch. Before I discover the magic smoke again, has anyone run into this issue? Am I just testing control incorrectly? Thank you for any advice
Control of the spindle via hitachi usb software or manual control still works perfectly. Mach 3 seems to be my bottleneck.
Setup-
Ethernet Smooth stepper
G540
Wj200
Mach3
Spindle - 2.2 kw 220v 400hz 240000r/min
Since I am used to manual control of the spindle, setting the Hz from 0-400 via F001 has been my go-to. I would love mach and the spindle to read-out rpm but I will be fine if that's not possible.
