586,024 active members*
4,064 visitors online*
Page 3 of 3 123
Results 41 to 49 of 49
  1. #41
    Pics of straight splines machined on multus, one with hob cutter, the other was done with a skive...
  2. #42
    Here is a pic of the taper spline kicking my butt. Currently sending these out to be done on a "universal" type hobbing machine.
  3. #43
    May 2015
    15
    Re: Diagonal Hobbing
    Hi Corey, how did Gleason recommend to cut these Splines? I have some experience with gear cutting on "universal" machines, my Multus does not have the gear option.
    It looks to me that you have to move in X-Y-Z at same time to get the tapered bottom? Not sure that the Okuma "gui" can do that since that is a little special even on universal machines.
    Is it possible to engage synchronization on the two spindles and long hand program it from there?
    Best regards Master8laster
  4. #44
    Jun 2015
    4154
    hi, it should work : if you can deliver the operation without restart/corections, then a simple long-hand should work
    to achieve repetability on same part ( offset corection, restart, etc ), then the special function is required, in order to sync the rotary M-S phases; another benefit of the special function is the " custom behaviour " during feed-hold, that avoids stopping the tool inside the material, by using a clearance position / kindly
  5. #45
    Jun 2015
    4154
    hi master blaster, another method, to deliver the part, without buying the special function, is only to rough it, then to finish it using the C axis + another tool (1 or more) that are not gear hobs; using c axis to program this, has a big chance to deliver a discontinuous motion, that may damage larger tools, like hobs eg
    it takes longer, requires C axis code ( which is not common ), and using the probe ( or another method ) to locate C axis zero ( which requires custom probe calibration, and may not work, since the contact point will not be alinged with the probe moving direction, and this is a problem when probing tilted surfaces, unless you have a probe for such things, or you know how to use a 'normal' probe; or use a 3d taster, calibrated, and tested on tilted surfaces ) / kindly
  6. #46
    Quote Originally Posted by master8laster View Post
    Gleason was a disappointment. They wouldn't even talk to me about it. When I try to long hand the x move it wipes the teeth.
  7. #47
    May 2015
    15
    Quote Originally Posted by coreywadeadams View Post
    So you programmed an X-Y-Z move?
    I have never seen this type of spline before to be honest, but its the only way I can see it being machined.
    I'd probably start with a piece of plastic and dial it in, that hob is not cheap.
  8. #48
    hello i want to do this
    taper hob
    https://www.youtube.com/watch?v=-tMFFNpVaxU
    macnine doosan puma tt2500sy
  9. #49
    for doosan puma tt2500 sy
Page 3 of 3 123
  1. Diagonal movements
    By dp341 in forum Chinese Machines
    Last Post: 05-21-2017, 01:01 PM
  2. Problema al cortar en diagonal
    By perico5000 in forum Spanish
    Last Post: 03-29-2011, 09:10 PM
  3. MB3-screen goes diagonal sometimes
    By underdog in forum HURCO
    Last Post: 01-16-2011, 05:35 PM
  4. Mach3 shooting off in diagonal
    By Malkaelan in forum Mach Software (ArtSoft software)
    Last Post: 05-09-2009, 04:44 PM
