585,908 active members*
3,704 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > AM882 solid red led, no green led
Results 1 to 3 of 3
    May 2017
    31
    I have 4 Am882's I'm in the process of setting up one of them initially had a green led and flashing red (Wiring was wrong for nema's) but not it displays only red.
    I've changed the plug and tried the plugs from the other AM882's as well as trying it's plug in them they all work flashing green this one is red.
    It's not in the manual, anyone else experienced this? Am I looking at a scrap AM882.
    35538
    Re: AM882 solid red led, no green led
    Try disconnecting the motor, then power off, then power on the drive.
    May 2017
    31
    Have done many times, tried it at 24v still red led, I have bought a new AM882 to replace it, this one is an AM882h which support AC and DC in so I'm going to see what happens when I feed it 50v AC.
  1. AM882 Drivers setup cable
    By joel0407 in forum Stepper Motors / Drives
    Last Post: 07-26-2017, 03:45 PM
  2. Need advice Leadshine AM882
    By IN-WondeR in forum Leadshine
    Last Post: 04-14-2017, 02:24 PM
  3. Replies: 9
    Last Post: 06-01-2015, 03:27 AM
  4. AM882 heats motors up
    By Antennas in forum Leadshine
    Last Post: 05-10-2015, 02:26 AM
  5. HELP! C35 BOB: RJ45 to AM882 driver.
    By rotule in forum Stepper Motors / Drives
    Last Post: 04-05-2014, 05:36 PM
