585,670 active members*
4,654 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > My PCNC 1100 Does not like to move.
    Nov 2017
    Moved my PCNC 1100 for the second time and have nothing but problems once again.
    First off i started her up and got two red lights, one on the z axis, one on the x axis, Y is green still so is the fuses. ( no blown fuses)
    Spindle wont move either.. Dont know really where to start now.
    thanks,
    Brad
    Mar 2015
    178
    Re: My PCNC 1100 Does not like to move.
    Brad what series is your mill? My series 3 has 3 stepper drives one for each axis. I only see one on yours.
    Not saying your other drives fell out in the move but
    Maybe the older ones used all axes in one type drive.
    To me the likely suspect is loose wire assuming all the fuses check good. I'd go one by one and check tightness.
    Nov 2017
    Hi Paul-JB
    Mine is a PCNC 1100 is a series 1. I had to upgrade one of the drivers because she blew when i set her up the first time.
    I have checked every single wire. I dont know what im missing. Hopefully nothing serious.
    thanks,
    brad
    Nov 2012
    104
    I had the main fuse/breaker pop once and I had the same symptoms. put in new ones and everything worked just fine after that. maybe u pinched the main power cord? if all u did was move it nothing should have changed to where now it doesn't work.
    good luck
    Carlos
    Jun 2004
    6618
    If you are running this on a 220 breaker, make sure you are getting the power you need from each leg.
    I had a breaker only deliver partial power to one side before.
    Not sure what was wrong with it. It was a really old one though.
    Lee
  1. Need to Pickup and Move a PCNC 1100
    By matinski in forum Tormach Personal CNC Mill
    Last Post: 11-01-2017, 06:14 AM
  2. PCNC 1100 vs PCNC 770 (Is the 1100 worth it)
    By thunderdork in forum Tormach Personal CNC Mill
    Last Post: 09-21-2016, 08:43 PM
  3. Move control cabinet outside of enclosure PCNC 1100
    By Strip in forum Tormach Personal CNC Mill
    Last Post: 02-24-2016, 11:26 PM
  4. PCNC 1100 G00 Rapid Move
    By psimos in forum Tormach Personal CNC Mill
    Last Post: 09-21-2013, 07:52 AM
