585,753 active members*
3,940 visitors online*
    Nov 2017
    Plasma tip dragging on steel
    I have a machitech EC 300 plasma table hooked up to a 105 hypotherm plasma ... when I run a program my tip drags on the part getting cut anyone explain why it's doing this ?
    Jan 2008
    2247
    Most likely your arc voltage setting is to low. Increase the set voltage until it runs at the correct height, which is .06". If you are not sure how to do this contact Machitech technical service. Jim Colt. Hypertherm
    QUOTE=mrobs;2114522]I have a machitech EC 300 plasma table hooked up to a 105 hypotherm plasma ... when I run a program my tip drags on the part getting cut anyone explain why it's doing this ?[/QUOTE]
    Nov 2017
    Thanks ... it's a used machine so I don't have so support ... my machine has the ec301 thc control ... it I tried adjusting it .. still seems to drag ?
    Quote Originally Posted by jimcolt View Post
    [/QUOTE]
  1. Motor Dragging Mid Cut
    By legendarysoundd in forum Machines running Mach Software
    Last Post: 08-24-2018, 05:14 PM
  2. Bobcad V26 bug when dragging
    By tchapman1000 in forum BobCad-Cam
    Last Post: 07-11-2017, 02:39 AM
  3. Motor Dragging Mid Cut
    By legendarysoundd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-19-2015, 02:06 AM
  4. Motor Dragging Mid Cut
    By legendarysoundd in forum Mach Mill
    Last Post: 03-19-2015, 01:00 AM
  5. Dragging Items around
    By bundysax in forum Mastercam
    Last Post: 09-03-2011, 01:05 AM
