I have a new Kitamura Mycenter 4 with I80MB control which we can't get to do anything. We just bought the machine and moved it here but the machine had been sitting in storage for several months.
The only alarms we have are
3000 Servo off
1032 NC alarm
I had a previous alarm which we have bypassed by jumping LN to wire 40
1011 2nd Limit alarm
The 4th and 5th axis are disabled, the table is disconnected from the machine and the 5th axis drive is not connected at all. The 4th axis drive has the Honda plugs disconnected.
I have also tried changing the 1020 parameters bits 0,1 and 2 individually which disables ZY and X axis
Any help would be appreciated. all drives have a green light, I have OHM'ed out the power wires from the drives to motors, I have not found any breakers tripped, the parameters match fairly well with the original parameter list and I can't find any loose wires.
The machine is showing 0 as position on all axis.
Thank you for any help.
