585,557 active members*
3,267 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 removing table endcaps
Results 1 to 6 of 6
    Oct 2017
    17
    Hi guys, total newbie here who can't figure out how to remove the table end caps. I see that there are two cap screws easy to remove but there are these sunk in screws which I've tried unscrewing with Allen key wrenches. I've seen people online doing the conversion using tools with T-handles not sure if they were hex or torx
    Thanks guys
    Mar 2007
    2083
    Re: G0704 removing table endcaps
    have a look at this PDF exploded parts diagram :=
    jpeg of part of PDF page1
Name:	part G0704 parts diagram.jpg
    John
    Attached Thumbnails Attached Thumbnails g0704_pl.pdf
    Oct 2017
    17
    Quote Originally Posted by john-100 View Post
    John
    Thanks John! Its M6 threaded sleeve. You actually put a red box on there for me. Really appreciate it. However I feel stupid, I googled tools to remove threaded sleeve and can't find any information on how to unscrew it
    Oct 2017
    17
    I figured it out, got it removed. Needed a screw extractor set. Got them out pretty easy. Thanks again
    Mar 2007
    2083
    just found this video ,
    https://www.youtube.com/watch?v=rheUeIK4X9E
    watch at about 1 minute in
    John
    Oct 2013
    543
    Addman16,
    Do you have a 'tinkerer' friend you might partner with on your project? Removing the 'end caps' would be a fairly obvious endeavor as would identifying the type of fastener and what tool would be required to remove it. Much more difficult challenges lay ahead and a 'gearhead' buddy would be a real plus.
    Stuart
    Edit. Whoops..guess you were confused over the roll pins..not the SHCS...sorry.
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  1. Need help removing Partner 1 table
    By lotsa luck in forum Milltronics
    Last Post: 02-15-2015, 05:34 AM
  2. G0704 Removing Head
    By DonKes in forum Benchtop Machines
    Last Post: 04-16-2013, 03:14 AM
  3. BP Series 1- Help removing the table after tip-over unloading!
    By winegar in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2011, 08:16 PM
  4. Removing table on Super Minimill
    By MKproto in forum Haas Mills
    Last Post: 02-17-2010, 04:00 PM
  5. RFQ Custom Motor Endcaps
    By JustinM in forum Employment Opportunity
    Last Post: 07-20-2006, 07:03 PM
