585,877 active members*
3,081 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Lathe ATC not on height - how do pro's fix this?
    Feb 2012
    26
    Hi all,
    Recently received my 330x700 lathe with a 6 station ATC. The ATC is designed to take 16x16mm tools
    Installed my the tools I ordered a while ago for my manual lathe to get me started and found that the tools were very low on the centre. So ok, problem I thought I could shim. Unfortunately nope...The top of the ATC slot, which is fixed, is too low.
    I could skim down my lathe tools but that does not feel right.
    I installed a 16x16mm parallel in the ATC and took a measurement to the centreline and the top of the parallel was 2.3mm lower than the spindle centre.
    Queried this with the manufacturer and they came back saying I should buy tools that take support shims under the insert. Fair enough I thought, so I looked for a while and I see that shims only come in 1 or 2 thicknesses.
    So as I understand it, the cutting edge of the indexable lathe tools should be at the same height of the shank right?
    Do I need to pack the ATC up by 2.3mm?
    Unlike manual machine QTC's you can't adjust each tool using a knurled nut, hence I am asking for opinions from users with ATC's that know how indexable tools work.
    Thanks in advance!
    Aug 2016
    132
    Re: Lathe ATC not on height - how do pro's fix this?
    Shimming the turret seems to be the simplest solution. Do you have access to a surface grinder?
    What brand of lathe do you have?
    Feb 2012
    26
    Thank for the reply, trying to find the installation manual for just the ATC is proving hard work.
    Surface grinding a small stock like the one needed here is not an issue.
    The machine was purchased through a trader in China that is helping me with the aftercare too. She organises all my machine tool purchases for Emvioeng.com Just need to make sure I am asking the right questions.
  1. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  2. Z height help
    By RCraig2 in forum G-Code Programing
    Last Post: 08-20-2014, 06:36 PM
  3. Thread height (BobCAD Lathe)
    By Hood in forum BobCad-Cam
    Last Post: 09-03-2013, 08:20 PM
  4. Lathe Working Height
    By Russ Kaiser in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2011, 07:49 PM
  5. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
