585,567 active members*
3,552 visitors online*
Results 1 to 1 of 1
    Oct 2006
    10
    Understanding Quick Change Tailstock Options
    I've been making something like a 3/4" cross-drilled brass spacer that requires spotting then center drilling 1/2" round brass before I part it off. After a couple hundred pieces, I'm sick of swapping two different bits into my tailstock Jacob's chuck. This is on an MT2 tailstock in my HF 3-in-1.
    I'm looking at tailstock turret that takes 5/8" straight shaft tooling. Looks like I can get a couple of collet chucks that can be mounted with the bits I need, or use Jacob's chucks.
    But are those import tailstock turrets rigid enough? I'm a far far cry from precision machining, but I do need a fairly well centered hole, and the business end of my tool is going to be a long ways from the actual tailstock.
    Then I see they make quick change collets. How quick are they? It looks like you have to unscrew a retainer nut to swap collets, and that would take longer than getting things in and out of a single Jacob's chuck. They look nice and stiff, but slow. If I'm missing something let me know.
    I also saw quick change tool post, but those aren't a super good option for what I'm doing.
    Any suggestions or experiences are welcome.
    thanks
  1. Replies: 3
    Last Post: 09-25-2017, 01:42 AM
  2. Replies: 2
    Last Post: 01-13-2017, 09:03 PM
  3. Mazak Quick turn 200 tailstock
    By MTCman in forum EMCO CNC Machines
    Last Post: 04-13-2016, 05:29 PM
  4. SL30 tailstock stroke change
    By djm77 in forum Haas Lathes
    Last Post: 04-25-2014, 07:14 PM
  5. Help understanding tool change restart speeds?
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 08-21-2011, 09:36 PM
