585,754 active members*
3,823 visitors online*
IndustryArena Forum > CAM Software > Vectric > Post Processors > need help with post procesor for mazak 530c with smooth g
    Jun 2017
    8
    hi.
    my workplace bought a new mazak 530c with smooth g controller in April.
    and I am just starting to test out fusion to our 4'th axis. I have some problem with the post processor.
    when I post the code, the post process do not write the movement for the A axis. it will use something called TCP(tool center on point, I believe it was) my machine do not have that function.
    do anyone have a modified post processor ? ore maybe someone can tell me how I modify the one I have, so that the post process writes the code for the A axis?
    now I am using the 4'th axis post process for HAAS but the code needs a lot of tweaking after being posted. and it is starting to take a lot of my time that I don't have.
    PS: I am not at all sure how to make changes to a post processor.
    I am thankful for all help I can get.
    Aug 2016
    119
    Re: need help with post procesor for mazak 530c with smooth g
    Quote Originally Posted by perinj95 View Post
    hi.
    When you go to post process your code, choose your post processor and click on config.
    The *.cps files are based on Javascript.
    Can't help with the rest I'm afraid. I'm just learning myself and I'm working with 2.5D lasers.
    This is a good resource too:
    https://forums.autodesk.com/t5/hsm-p...forum/bd-p/218
    Jun 2017
    8
    the machine i use don't have the option G43.5
    and fusion wants to use G43.5 insted of writing
    this is what i want when i post it (this is just an example
    N30 T14 M6
    N35 S5540 M3
    N40 G54
    N45 M11
    N50 G0 A-17.98
    N55 M8
    N65 G0 X86.314 Y0.
    N70 G43 Z179.35 H14
    N75 G93 G1 A-17.98 F88.84
    N80 G94 Z169.35 F5000.
    N85 Z168.055
    N90 Z166.855 F1000.
    N95 G93 X85.997 Z166.841 A-17.89 F577.41
    N100 X85.665 Z166.827 A-17.809 F586.79
    N105 X85.318 Z166.814 A-17.737 F599.41
    but this is what i get
    N16 T14 M6
    N18 S5540 M3
    N20 G54
    N22 M8
    N24 G43.5 G0 I0. J-0.309 K0.951
    N26 X86.314 Y-55.361
    N28 Z170.592
    N30 X86.314 Y-55.361 Z170.592 I0. J-0.308677 K0.951167
    N32 X86.314 Y-52.274 Z161.08 I0. J-0.308677 K0.951167
    N34 X86.314 Y-51.875 Z159.848 I0. J-0.308677 K0.951167
    N36 G1 X86.314 Y-51.504 Z158.707 I0. J-0.308677 K0.951167 F1000.
    N38 X85.997 Y-51.252 Z158.774 I0. J-0.307193 K0.951647 F333.33
    N40 X85.665 Y-51.024 Z158.833 I0. J-0.30585 K0.95208
    i have ben playing around whit haas post prosecc but it don't work at all like i want it to, the program needs a lot of changes
    Anyone that can tell me in detail how o can make this work ?
    Jun 2017
    8
    N30 T14 M6
    N35 S5540 M3
    N40 G54
    N45 M11
    N50 G0 A-17.98
    N55 M8
    N65 G0 X86.314 Y0.
    N70 G43 Z179.35 H14
    N85 Z168.055
    N90 Z166.855 F1000.
    N16 T14 M6
    N18 S5540 M3
    N20 G54
    N22 M8
    N28 Z170.592
  1. ARTCAM POST PROCESOR
    By Miron.Costin in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-13-2017, 08:29 AM
  2. mazak vcn 530c
    By perinj95 in forum Vertical Mill, Lathe Project Log
    Last Post: 06-17-2017, 09:35 PM
  3. Mazak VCN 530C vs Mazak VCS 530C
    By JeremyMinnesota in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2013, 09:53 PM
  4. GibbsCam Post Procesor
    By bbjang in forum GibbsCAM
    Last Post: 12-13-2012, 05:54 PM
  5. Replies: 3
    Last Post: 02-18-2010, 06:16 PM
