I'm looking for a solution to fix a clunking noise when I manually move my z-axis. I have a G0704 Grizzly Mill that has been converted to CNC with a G540 Gecko Drive. I believe the noise is caused by some backwards current being produced from spinning the motor because if I disconnect the motor from the Gecko drive the noise disappears. I have attached a video of the noise when the motor is connected to the G540. Here is the motor used on the z-axis: https://www.automationtechnologiesin...l34h295-43-8a/
