585,744 active members*
4,522 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Has anybody ever met 'The Denbigh' Milling machine?
Results 1 to 3 of 3
    Mar 2006
    62
    I am currently trying to find a manual for 'The Denbigh' C.V.S. Milling machine.
    I am having the following problems..
    I can't seem to adjust the tension of the motor drive belt - it looks like the whole assembley rotates and is held in place by one bolt. The bolt moves but the motor does not. Would a belt dressing on the leather belt prevent slip?
    The lathes.co.uk indicates that the table has power feed in both directions. Mine only seems to have 4 speed powerfeed in one direction.
    Also, the powerfeed seems to 'slip' - it can be engaged but if you hold the table handle it just stops the drive shaft turning.
    Thanks!
    Oct 2012
    29
    Re: Has anybody ever met 'The Denbigh' Milling machine?
    Very old post. I read you have to replace the belt when it slips. have you still got the machine ?
    May 2020
    3
    but why this post seen in the upper section?
  1. Need a Machine Manual for a Comet Milling Machine
    By metalman7290 in forum Machinery Manuals / Brochures
    Last Post: 09-12-2020, 06:56 PM
  2. Milling a plastic with a CNC 770 milling machine
    By Edmond Young in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-12-2013, 02:55 PM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
