I am currently trying to find a manual for 'The Denbigh' C.V.S. Milling machine.
I am having the following problems..
I can't seem to adjust the tension of the motor drive belt - it looks like the whole assembley rotates and is held in place by one bolt. The bolt moves but the motor does not. Would a belt dressing on the leather belt prevent slip?
The lathes.co.uk indicates that the table has power feed in both directions. Mine only seems to have 4 speed powerfeed in one direction.
Also, the powerfeed seems to 'slip' - it can be engaged but if you hold the table handle it just stops the drive shaft turning.
Thanks!
