585,762 active members*
4,092 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Nov 2017
    12
    Uploading to Biesse
    Hey, this may be a dumb question but, I have a Biesse Rover B 7.4 Ft. And I just got a postprocessor from Bobcad for it. The post out puts the file as NC and the machine reads ISO and BPP. So I was wondering how do i upload a NC file and convert it to an ISO or BPP file so that my machine can read the file
    Feb 2008
    38
    Re: Uploading to Biesse
    Quote Originally Posted by fdg35 View Post
    Hey just wondering how you are making out . we just are in the midst of installing a 2008 7.40 rover B FTK
    We had upgraded to version 30 last month but are considering mastercam ... lot more money but maybe we should give bobcad a fair shot at the business yet the seem too want $900.00 for the post which I had thought posts were free but guess not for a biesse machine
    My guess is that the .nc is the same as ISO, so editing the post processor to change the file extension may be all you need to do.
    Nov 2017
    12
    You see every time I try to run one of the iso files I have through BiesseWorks I get a pop-up that say "unexpected file format". And now I am stumped. The manual clearly says that the machine is capable of running iso files I just don't understand why I am getting that message
    Nov 2017
    12
    Quote Originally Posted by Irv Bea View Post
    I'm pretty sure all i should have to do is what Ger21 said which is simply change the file extension to .iso. but my Biesse doesn't seem to want to read any iso files.
    You might have to run it through Biesseworks or something like that??
    I've never used a Biesse, so don't really know.
    Feb 2008
    38
    ok I will prob end up buying a post from Bob cad had the mastercam guy out yesterday and for the simple drawings I do Bobcad has nicer and faster features . example drawing and angled line took him at least 4 times longer... and the software costs much more
    I have an old c53 thermwood I am currently using. and am looking for someone to train me on the biesse . I have the local biesse dealer scheduled to come out Dec 27, but if we find somebody sooner would be great
    Its gona be a learning curve to switch , but from my research Biesse is a common machine here in Ontario where I am
    Feb 2008
    38
    are you having any luck with Bobcad post processor to Biesse
    Nov 2017
    12
    umm.... sorta. i'm still working on learning how to read and set up Biesse code but it seems that the post they gave me is close to what i needed. But if youre looking for outstanding customer service i wouldnt go with BobCAD. I've been having trouble getting ahold of someone as well
    Feb 2008
    38
    Ive sorta hit my frustration limit with bobcad on the posting side
    I can post a code that works but it still has lots of quirks and needs to be edited manually yet
    and does moves in the rapid that are not required also the feeds and speeds don't listen at all , spindle speed does but not machining speed
    Bobcad I guess hasn’t developed a post that works properly wish they would have told me so
    we will move in another direction I guess
    Nov 2017
    12
    What are you trying to cut? Table? Cabinet?
    Can you post sample code?
    sounds like feeds and speeds are out of the range of speed parameters you have set in BobCAD. In CAM Tree right click "CAM Defaults". Click "Current Settings" Select in the "Make" selection box your Biesse post name, then edit machine parameters from there.
    Feb 2008
    38
    we do pvc sheets into exterior trim columns etc mostly straight lines and curves
    changing the seeds in the parmeters doesn't do it
    I have to do it in the tool settings and if I enter .6 for cutting feed rate it converts it in the post to 15 which biesse than reads as meters per minute ,
    so like I say there is quite a few quirks you have to learn to work with and what to enter so it comes out the correct number and this bobcad should be doing for me
    But its obvious the are still learning themselves it takes a long time for them to respond and longer yet to fix it , if they can fix it I don't know
    Nov 2017
    12
    Do you think you can post your Post processor file on here so I can have a look at it I might be able to fix your feed problem. And a posted program.
    Feb 2008
    38
    im not sure how to get the file on here
    feed isnt the only issue
    there is the issue on cad I have to use the lower left for my 0 0 points
    and than on the machine the 0 0 point is at the back left
    so everything in the y axis gets mirrored and Bobcad cant fix this for me
    I can reverse direction in y but not without the z axis also reversing , there has to be a bug in this v30 software Im convinced and Bobcad is sloooooooow to get back to me
    Ive wasted so much time a more expensive program from Day 1 would have been well worth my time
    Feb 2008
    38
    just an update
    with being lots on the phone and turbo meetings with Bobcad
    we finally have got the 00 where we want it , had to make a change in the post
    also they fixed the feeds and speed issue for me
    still have one little quirk that we are working on ,
    before it plunges in the z axis it retracts .75" from the rapid plane and than plunges down ,
    Feb 2008
    482
    i got around this 00 thing by drawing with 0 point in top left.
    changed my y values + - in the post
    changed - y to --y to create a plus (took ages to work that one out )
    i think i did same with z as on my biesse that was also backwards to modern convention
    so much to learn, so much to pass on.
    Feb 2008
    38
    Quote Originally Posted by battwell View Post
    we got that worked out and were doing some stuff that actually works
    but we just get a surprise package every now and than wit the z value cutting into our spoil board
    the Bobcad post does not work it was a waste off money and I have lost a lot off time and money with Bobcad
    Im going to try to get into biesseworks training
    and hopefully import dxf files into biesse works
    Nov 2017
    12
    Does your tool only crash into spoilboard right after and right before tool change?
    Feb 2008
    38
    No it was just before the first machining move it would peck into the spoilboard
    WE gave up on Bobcad
    If you want something that works invest into Alphacam and take the introductory online training,
    Which is what I did and have been smiling ever since
    The cix post that I got from alphacam works 100% with biesse , you can open the file in Biesse works and even adjust tool depth settings from there
    I cant say enough good about Alphacam and their cix post working seamlessly with Biesse
    Apr 2018
    34
    I have worked with both Bobcad and Mastercam.
    Bobcad. cheap to buy. expensive to operate. ALWAYS manually editing programs...very little control over 3d surfacing entry exit maneuvers...no gouge checking.
    This is what the boss bought because he wanted to save money. unfortunately I spend more time manually editing programs to work.
    I shouldn't have to...I don't think a FANUC is an exotic control..
    Mastercam ..expensive to buy. ..lots of control...it's what I get to use when I'm at my part time job...love it, but big learning curve....
Page 1 of 2 12
  1. Replies: 13
    Last Post: 10-21-2017, 06:02 PM
  2. uploading a program
    By dcutler35 in forum Mastercam
    Last Post: 07-22-2012, 02:36 AM
  3. Uploading to a Fanuc 6T
    By dizzypistons in forum Fanuc
    Last Post: 04-17-2012, 11:33 PM
  4. M32 CMT 515 error when uploading CMT-NC
    By kevotron in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-29-2007, 02:08 PM
