585,930 active members*
3,885 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Precision Matthews PM-940M (and it begins)
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    Jul 2017
    31
    Re: Precision Matthews PM-940M (and it begins)
    OK, from the last time I got the enclosure base mounted, welded, and sealed with sikaflex 1A, using regular sink drains for the coolant.
    Sitting down and ordering all my one shot oiling fittings and tubing so I can get that run and routed when I put the saddle and table back on.
    The enclosure base is 1/2 plate AL and the sides are welded on both sides and sealed with sikaflex 1A. Drains at the front so I can clean them easier.
  2. #42
    Dec 2015
    46
    Quote Originally Posted by wrastu View Post
    I have to admit, I didn't get how you was going to incorporate the platform that you built into your build, but now you have started building the chip pan it really ties everything together, and now I can fully see your thoughts about the mill stand not being wide enough.
    I actually had ideas to fill the mill stand with epoxy granite or just regular concrete when I get my mill, but after seeing your build it may be best to build a platform like you did then sit the mill on top of it, perhaps even still filling the base for extra weight.
    Looking forward to more updates on your build.
Page 3 of 3 123
  1. Precision matthews PM-940M Mill to CNC conversion
    By unknownpro in forum Benchtop Machines
    Last Post: 11-28-2016, 08:42 PM
  2. Replies: 4
    Last Post: 05-03-2015, 09:51 PM
  3. Precision Matthews PM-45M with 3 axis DRO
    By MUDSUX in forum Benchtop Machines
    Last Post: 03-13-2013, 02:30 AM
  4. Precision Matthews
    By cypressslough in forum Benchtop Machines
    Last Post: 07-30-2012, 09:54 PM
  5. Precision Matthews, GMC, or Victor
    By mtechserv in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2008, 07:11 PM
