585,760 active members*
3,866 visitors online*
    Nov 2017
    Post CNC Will Not Sloped Edge Modeled
    CNC Will Not CUT Sloped Edge Modeled**
    We are using a ShopBot 2-phase .5 degree/step CNC machine. The objects to be cut were originally created in Rhino. From the Rhino file, we exported STL files to set up cut settings in PartWorks.
    The objects we are trying to cut are 22" x 22" x 2" foam board. The foam boards are to have a cut out in the center, either triangular or circular. The piece pictured in the first image is more circular. The edges of the cut out are modeled in Rhino to have a gradual 1/4" slope from the top to the bottom. The second image is a wireframe right side image of a a more triangular cut out. As you can see, there it is sloped. But when we cut the piece on the machine, the edges are not sloped. The bit simply goes straight down. Is there some setting we are missing? Or any other reason for why we are not seeing a slope?
    Jun 2013
    1041
    Re: CNC Will Not Sloped Edge Modeled
    Looks like the model is upside down from the pic. If the smaller end of the slope is at the top in the model then any tool path would just drop to the bottom and make a circle. It can't reach the inside taper without gouging the part so cuts only what it can safely make contact with. Try flipping the model over an redoing your tool paths.
    Ben
    Sent from my HTC6525LVW using Tapatalk
  1. Advice on Sloped face off CAM Mill setup.
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 05-03-2014, 12:52 AM
  2. straight line sloped/slanted
    By lasernewb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-30-2011, 12:50 PM
  3. How do I cut a sloped line
    By scheek in forum WoodWorking Topics
    Last Post: 02-17-2011, 12:49 AM
  4. solid modeled tool path simulator
    By StarMan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-08-2006, 08:31 PM
  5. jgro router modeled in Catia
    By Sporqster in forum Commercial CNC Wood Routers
    Last Post: 10-05-2005, 09:00 PM
