585,927 active members*
3,876 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > NC SPEC File Encryption/Decryption
Results 1 to 13 of 13
    Aug 2011
    419
    I will explain OSP NC spec encryption algorithm soon.
    There will be no such thing as "OPTIONAL"
    "Imagination is more important than knowledge."
    Apr 2014
    18
    Re: NC SPEC File Encryption/Decryption
    Hi kurmay, any news?
    Inviato dal mio LG-H850 utilizzando Tapatalk
    Aug 2011
    419
    Apr 2014
    18
    it is not very clear to me.
    Do you unlocked something?
    Aug 2011
    419
    It is very clear for someone's.
    Apr 2014
    18
    Hi kurmay,
    what are the bytes after the asterisks? I haven't them.
    is encryption performed with these bytes?
    My spec file is different.
    Can you help me to understand? Please
    Jun 2015
    4154
    i think i got it
    Apr 2009
    1262
    So without encryption algorithm we have nothing right?
    Experience is what you get just after you needed it.
    Dec 2012
    15
    if this helps,here is same block for serial 105941
    So do you think proper encryption...or maybe just obfuscation? bit shift/ or add subract serial number? Shame we don't have exact same machine before after an okuma optional feature add. I'm doubtful of AES or DES encryption as US/JAPAN export/import rules would limit many encryption algorithms....plus CPU isn't monster on older machines.
    Let me know if I can help in your endeavor.
    Oct 2006
    14
    5020L controls. Can I increase the memory? Would this be related?
    Apr 2009
    1262
    Kind of related. First level upgrade is bit setting only. Unfortunately it just changes mapping if BB0: and BB1: so you already have useable memory in BB0: . Yes you can use it but don't fill it or you'll get into trouble.
    Next levels actually add hardware to increase memory. Expensive and may no longer be available through Okuma.
    Best regards,
    Ps> hello mcCoyheavy... how's the fecon working? ;-)
    Aug 2018
    4
    Red face
    Can you help me, where can i find the ec spec and nc spec code, or what filename should i locate those spec code.
    Attached is the OSP management card.
    For LT15-MY
    5020L
    Thanks.
    Aug 2011
    419
    File name is LCU06-00-A.PBU for 5000series lathes.
    You can find in BB0 memory.
  1. v1.9.11 decryption issue, any one else???????????
    By TPR in forum Tormach PathPilot™
    Last Post: 07-14-2017, 11:55 AM
  2. GStarICAD Drawings Encryption
    By cad_haochen in forum Uncategorised CAD Discussion
    Last Post: 03-23-2009, 08:10 AM
  3. The spec for file formats on our DSPs
    By Kent_Norway in forum Excitech routers
    Last Post: 08-18-2008, 12:15 PM
  4. Cold Boot Attacks on Encryption Keys
    By CheekieMonkies in forum Computers / Desktops / Networking
    Last Post: 03-05-2008, 01:08 PM
  5. Need to know the spec. of this stepper
    By CrazyRonny in forum CNC Machine Related Electronics
    Last Post: 05-27-2004, 04:28 AM
